crgauth
#1 Posted : Monday, January 28, 2008 6:27:31 PM(UTC)
crgauth
Not sure if my washer is filling up far enough. Any way to tell how far it should fill? I know it depends on the level setting, but want to start with it set all the way up. I think the water level knob may be broken as it spins all the way around. It does continue to fill if I hold it on reset, but if I turn to hard, it spins down to mini basket.
#2 Posted : Tuesday, January 29, 2008 1:03:41 PM(UTC)
Remove the knob and inspect for any cracks from inside.
Check if the knob insert is in place.
UserPostedImage
Here are the break down diagrams for the GE washer Model WWA8350GAL
crgauth
#3 Posted : Tuesday, January 29, 2008 5:07:56 PM(UTC)
crgauth
I may not have been clear. It is not the external knob that I believe is bad, but the switch behind it. Any way to test it?
