HandyMike
#1 Posted : Tuesday, September 22, 2009 7:22:34 PM(UTC)
HandyMike
My GE Adora washer locks the door, goes into a quick fill cycle (12-15 seconds) the drum turns 1/4 of a turn then the system goes into a dump mode and drains the water out for about 7 seconds then the pump continues to run for almost 3 minutes..... Door unlocks and washer goes into pause mode??? I have taken the lint trap off and cleaned it, I have pulled the pump, drain hose & rubber boot out and checked it for any obstructions and now, IM STUMPED!!!!:confused: I think my only option is the control board??? Anyone got any I-DEARS?
sidfink43
#2 Posted : Wednesday, September 23, 2009 3:48:50 PM(UTC)
sidfink43
Sounds like, see if you can put it in test mode.
Here is the service manual.
http://appliancejunk.com/ge/washer/31-9135.pdf
HandyMike
#3 Posted : Sunday, September 27, 2009 7:08:50 PM(UTC)
HandyMike
Is there a service manual available for a GE Adora Dryer???
sidfink43
#4 Posted : Monday, September 28, 2009 3:10:26 AM(UTC)
sidfink43
GE is very close with their technical info, and I do not have access to one.
Maybe someone else can post a link.
