AppliancePartsPros.com
Appliance Repair Help
Washer Repair
ge washer makes lound grinding noise is spin cycle.
Machine works fine except for the loud jet noise in spin cycle.
Check the drain pump for a foreign objects inside. If there is nothing wrong then, most likely the problem is the transmission/breaks assembly. - The part number for the drain pump is AP3193205 -The part number for the transmission/break assembly is AP2046402 Gene.
my washer is loud during the spin cycle but also the tub seems to be moving all around, did this happen to your washer as well?
Hi Jennie,
What is the complete model number of the washer?
Post it as a new thread, please.
Im not sure if this is where the new thread goes but model number is lsq8243hqo
The first thing I would do is remove the washer cabinet, remove the drain pump and check for a foreign objects inside the pump. Also check for a foreign objects between the inner and the outer tubs. Check the suspension parts. Here are the break down diagrams for the Whirlpool washer Model LSQ8243HQ0Gene.
Originally Posted by: Jennie Ortega ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) my washer is loud during the spin cycle but also the tub seems to be moving all around, did this happen to your washer as well? ![UserPostedImage](http://forum.appliancepartspros.com/images/icons/icon6.gif) Yes it does. Alan
To both... If these are new machines like within a year the spanner nuts have been coming loose on them and the basket itself is just flopping around in it.. Will need new spanner nuts and lock ring... and depending on ho long it ran a new basket
Washer Repair
