my frigidaire crown dryer all of a sudden wont heat up to dry clothes, clean all areas still no heat. is there a fuse or something that we can replace and if so how and where is it at.
First check to make sure that you have 120v coming to each side of the connection block
Then unplug the dryer and insert a putty knife or screw driver in the gap between the top and front near the edges. This will release clips that hold the top to the cabinet and it will flip up. Then take off the front. This will expose the heater asembly and the blower cover which will have thermostats/thermal fuses for you to check for continuity. Finally check the heating element for a break.
