2 Pages12>
Chris L
#1 Posted : Monday, January 28, 2008 6:39:08 AM(UTC)
Chris L
My problem seems to be intermitent and going on for quite some time. After a full cycle the close on the bottom are soaked. I replaced the timer because i thought it was skipping the drain cycle but i think it was me messing it up while tring to peek in. I now bypassed the lid switch and noticed the high speed cycle is not very high, i also here water falling back down into the tub. When its done there is a hint of motor smell. If i go back to high speed spin it spins very fast! The pump is pumping during the cycles cause i see and here it! The drain is under the max at 6.5' high. Thanks for the help, Chris
#2 Posted : Monday, January 28, 2008 2:56:57 PM(UTC)
Hi Chris,
Check if the motor hot to the end of the cycle. Possible this is a motor.
Chris L
#3 Posted : Tuesday, January 29, 2008 1:12:16 PM(UTC)
Chris L
Ill have to check that. If it is a motor problem, is it worth fixing? A while back a local repair shop said maybe a pressure switch. Does this make any sence?
Its odd that it would spin slow on the full cycle and as soon as you go back to the high spin setting, it spins fast! Thanks again.
nu1ni
#4 Posted : Tuesday, January 29, 2008 1:56:14 PM(UTC)
nu1ni
My Kenmore washer is about 30 years old. A year ago, I noticed that the clothes were dripping wet after the delicate and cotton cycles. I just began using the perma prest cycle exclusively. Now the clothes are wet after that cycle as well - but only sometimes. When it happens, I just manually set the spin cycle, and it works. Just yesterday, this manual setting stopped working. So the clothes are still dripping wet and I get a a burnt smell to boot.
I would like to fix this machine. Any suggestions about which part may need replacing?
Chris L
#5 Posted : Monday, February 11, 2008 6:14:40 AM(UTC)
Chris L
Today i smell alot of motor! After 20min or so i pulled it out and the motor was still warm. This is a 2 speed motor, is it possible that only one speed is working? If so can anything else besides a motor cause only one
speed to work? Thanks again.
#6 Posted : Monday, February 11, 2008 8:13:13 AM(UTC)
Hi Chris,
There is 99% chance that the motor has to be replaced. It has two different windings for each speed and one of them gone bad.
- The part number for the motor is AP2905451
Here are the break down diagrams for the Whirlpool washer Model LSQ9549LW0
Chris L
#7 Posted : Monday, February 11, 2008 9:50:21 AM(UTC)
Chris L
Thanks again. Im gonna order the motor, im determined to fix this. Is there any thing else i should order with the motor since it will be apart? like the rubber grommet or motor coupling? Im pretty good with fixing anything, but is there any tricks to replacing this? Should anything be lubed while im at it? Thanks
#8 Posted : Monday, February 11, 2008 10:15:09 AM(UTC)
I would recommend to replace the motor coupling at the same time.
There is nothing to lubricate and this is not too difficult to do yourself (especially with the complete instructions).
- The part number for the motor coupling is AP3963893
richappy
#9 Posted : Tuesday, February 12, 2008 1:49:20 AM(UTC)
richappy
I would also pull the cover off the timer and check for burnt contacts, if so, you will need a new timer also, lots of times a bad timer will burn out the motor. If bad, you are looking at a big bill for parts, like $180, maybe not worth fixing.
Chris L
#10 Posted : Tuesday, February 12, 2008 7:03:56 AM(UTC)
Chris L
I did change the timer because i thought it was skipping some cycles, but i think it was me tring to peek in. So in a way i guess its better i did change it! I did order the parts and ill post the out come! Hopfully it works cause the one my wife wants next is like 1000 bucks!
Guest (8)
2 Pages12>
