MVMOORE70
#1 Posted : Friday, September 25, 2009 4:54:57 AM(UTC)
MVMOORE70
My GE upright has ice and frost buildup at the bottom-back of the freezer where it used to blow cold air. Doesn't feel like any air is blowing. I unplugged it to allow it to completely defrost and have the same problem. I did the dollar test and it didn't come out easily at all, suction seems to still be pretty good. It seems to be a motor going, but I'm not sure what it is. The food has almost completely thawed and I don't know what to do. I hope this is something that I can repair myself, as I am very handy. If not, I'm wondering if I should just buy a new one. Thanks guys.
#2 Posted : Friday, September 25, 2009 6:06:27 AM(UTC)
If the unit has auto defrost then that may be your original problem.
Remove the evaporator coil cover so you can see the coils.
Are they getting cold?
Is there a frost pattern that is fairly even over the entire coil?
If there is an evaporator fan, is it running?
Is the compressor running?
I would not buy a new unit until I was confident that I knew what was wrong with the old one.
Here is a good site with repair info
http://www.applianceaid.com/repair-help.html
Note that much of the info on refidgerators will also apply to you if your unit has auto defrost.
MVMOORE70
#3 Posted : Friday, September 25, 2009 11:51:49 AM(UTC)
MVMOORE70
It is auto defrost. I don't know how to get to the things you mentioned.
#4 Posted : Friday, September 25, 2009 12:04:57 PM(UTC)
Perhaps with a Model Number someone who frequents this forum may be able to help.
