Philip Wolke
#1 Posted : Saturday, September 22, 2007 11:41:16 AM(UTC)
Philip Wolke
I have read the other posts reguarding this problem. My dishwasher is filling just fine. I took the advise from another post and added 1/2 gallon of water just to make sure. My lower arm is still not turning.
The last couple of loads has left hard soap residue on my dishes. Then, the last load I washed the soap was still sitting on the bottom of the dishwasher and all over the plates by the soap dispenser. I ran it through another cycle with the same results. I washed the load by hand and ran it through another cycle with no dishes. The soap is still on the door and the bottom of my dishwasher.
During this last cycle I have opened the door many times and the spray arm never moves.
Im not sure what to try next.
Thanks for your help.
richappy
#2 Posted : Sunday, September 23, 2007 2:51:11 AM(UTC)
richappy
Remove spray arm and clean out the holes. Remove plastic spray arm base. Pull the micro screen filter and clean if clogged. If ok check for a bad impeller or stuff stuck near the impeller.
fyxer
#3 Posted : Sunday, January 27, 2008 9:22:24 AM(UTC)
fyxer
You have water in the dishwasher so it is not a case of no water in the dishwasher, a common problem i see quite a lot is the wheels on the bottom drawer is missing so the drawer is resting on the spray arm preventing it from turning.
