mtfurtney
#1 Posted : Sunday, January 27, 2008 9:13:42 AM(UTC)
mtfurtney
I am getting an error code F2-E0 on my kenmore range.
How do I test the operation of the Door Lock?
How do I test the relay contact operation...and where is the relay?
How do I test the oven temperature sensor?
#2 Posted : Monday, January 28, 2008 9:27:39 AM(UTC)
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
Why do you want to test the door lock and the temperature sensor?
- The part number for the control board is AP3174668
In order to provide the right part number for the membrane switch I need the color of the control panel.
Guest
#3 Posted : Sunday, December 24, 2023 9:52:16 PM(UTC)
Guest
My krnmore control board says Eo F2 mod 665.72132300 how can I fix it. Thanks.
