Voyager15
#1 Posted : Saturday, January 26, 2008 9:00:26 AM(UTC)
Voyager15
Hi: This is second e-mail because first one had wrong model number on it. I have replaced the igniter, the coils, and the flame sensor, but it still does not get hot. With the drum out of the unit, I turn it on and the igniter does not glow. The motor runs, the control panel works, and the door switch all work fine. This is the way it was when I started, even with all the new parts. Please help. Thank you.
ripleys
#2 Posted : Saturday, January 26, 2008 11:49:29 AM(UTC)
ripleys
Check the thermal fuse at the rear of the dryer. TURN OFF POWER! Take the back off and look for a little white piece by the vent has 2 wires going to it and is held in with a 1/4 inch hex head screw. Take off the two wires and join them together with black electrical tape and try the dryer. If everything starts wirking replace the fuse and CLEAN ALL YOUR EXTERNAL DUCTING!!
