mharwell01
#1 Posted : Monday, September 21, 2009 11:59:10 AM(UTC)
mharwell01
My ice maker is not filling with water. Supply tube is clear not frozen. I have current at the wire to the water valve when it cycles. When I check continuity on the solenoids, I get 190 ohms on the inlet and after filter 35w solenoids. Is this the correct resistance or are my solenoids bad? I notice on the 20w solenoids that go to the door water I get 300ohms. Here is my valve assembly if you need a visual.
UserPostedImage[URL="http://www.appliancepartspros.com/part_details_lgimg.aspx?part_id=2071734&image=1"][/URL]
#2 Posted : Monday, September 21, 2009 8:02:53 PM(UTC)
Quote:
...I have current at the wire to the water valve when it cycles...
How did you find it? What about voltage?
