jwhite22
#1 Posted : Monday, September 21, 2009 8:11:57 AM(UTC)
jwhite22
washing machine pump leaking. is this as easy as it looks or should a repair man be called. i see to hoses is that all to fixing the problem
sidfink43
#2 Posted : Monday, September 21, 2009 5:13:23 PM(UTC)
sidfink43
Hi Jimmy
I cannot get your model number to come up, but if this is the standard direct drive top loader, it is as easy as it looks. After you have the cabinet off, the pump comes off by releasing the two clips and taking off the hoses (water will come out) Replace the pump and you are all set.
SublimeMasterJW
#3 Posted : Monday, September 21, 2009 5:20:54 PM(UTC)
SublimeMasterJW
The exact part
UserPostedImage
Use a screwdriver to remove the screws holding down the control panel,then swing it upwards.
UserPostedImage
Use a flat blade screwdriver to pop these Clips
UserPostedImage
Unplug the lid switch connection.
Tip the case forward and remove it.You will now be able to repair the washer!
UserPostedImage
FYI: The lid must be closed for spin on older washer. It must be closed for wash and spin on newer ones. The lid has a striker in it that pushes against the lid switch arm. This switch allows for spin IF the lid is closed. The switch may have failed. Mechanically the striker may be broken or the actuator arm may be broken. The end that the harness plugs into has 3 holes. As you can see above the lid switch has 3 wires. 2 live wires and one green ground. You can jump the washer out using a horseshoe shaped wire or equivilent. Newer models have the ground wire on one end. Not good! Look for that before attempting to jump it out. At any rate their are 3 wires. One of them is always green and always mounted to the frame. The other 2 are live. You can jump them to magically make that puppy spin and pump. Not recommended to leave it that way. For testing purposes only.
UserPostedImage
here is a broken lid switch
UserPostedImage
A 3 piece drive coupling
UserPostedImage
NOTE: some newer models have the screw hidden
UserPostedImage
Others have it in the rear as shown here.
Still newer ones have no screw at all, just spring clips.
Hay we don't need no stinking screws.
UserPostedImage
Here is a view of the washer with the case removed.
UserPostedImage
sidfink43
#4 Posted : Monday, September 21, 2009 5:23:48 PM(UTC)
sidfink43
Good call JW
If I had not been half asleep and watching the game I would have noticed that.
Jimmy T. (Dryer Repair)
by Jimmy T. 7/27/2013 5:41:06 PM(UTC)
jimmyb (Dryer Repair)
by jbradford 11/24/2009 6:07:56 PM(UTC)
