stan568
#1 Posted : Thursday, January 24, 2008 2:32:38 PM(UTC)
stan568
Hello All,
I have a problem with a dryer that won't start. The dryer was plugged in on a circuit that tripped at the breaker panel during heavy usage (dryer running and a hair dryer plugged in and used).
Once the power was restored at the panel, dryer would not start. When plugged in, can hear timer ticking. Tried to jump door switch, with no changes. Unable to determine if the lightbulb is good or not, but right now there is no light. No clicking sounds heard when pushing door switch or start switch, totally silent (things posted in other threads).
I will return tomorrow with my volt meter to check some things I have read about in some prior posts (timer, start switch, door switch, thermal fuse, high limit thermostat and cycling thermostat).
Anything else I could do to narrow down my search.
Any help much appreciated!
#2 Posted : Friday, January 25, 2008 1:08:17 PM(UTC)
You are on the right way.
- Here are the break down diagrams for the Maytag dryer Model SDG4000AWW
Post you findings, please.
stan568
#3 Posted : Saturday, January 26, 2008 11:39:22 AM(UTC)
stan568
Hello Gene,
Thanks for your quick response. I, however wasn't able to make it to the dryer as soon as I wanted to...but I finally got to it today.
As you have posted in your other threads, the first thing I checked was the thermal fuse and found it open. I jumped the fuse, and BINGO, the dryer started!
I proceeded to check the remaining fuses/switches, and found the heater thermostat also to be open. Should that also have continuity? The dryer is running, but I don't have it hooked to gas to see if it heats. The heater thermostat is part #11 on the motor and fan schematic.
Thanks again for your help with this relatively simple fix!
Stan
#4 Posted : Saturday, January 26, 2008 4:23:19 PM(UTC)
Hi Stan,
The heater thermostat should have some resistance, otherwise the dryer will work only on one temperature.
stan568
#5 Posted : Sunday, January 27, 2008 6:26:55 AM(UTC)
stan568
Gene,
The switch that I found open, the one I jumped and got the dryer to work, is not able to be found on the breakdown of parts. My particular combustion duct has two sensors on it.
One is flush mounted and mounted at approx at the 1-2 o'clock position on the duct while looking down the duct (this I believe to be the limit thermostat comparing to the pictures).
The faulty sensor is mounted at the 12 o'clock position, is mounted on a bracket that keeps it approx. 1 inch from the top of the duct, with a hole cut into the duct just below the sensor. The sensor and bracket are one piece and do not seperate from each other.
Any ideas which piece I need?
Thanks again Gene,
Stan
stan568
#6 Posted : Sunday, January 27, 2008 12:01:20 PM(UTC)
stan568
Gene,
I found what I need....I found a part number on the part to reference.
Thanks again!
Stan
Replaced belt, idler pulley, and rollers and now Maytag Dryer Wont Start (Dryer Repair)
by Guest 11/29/2022 8:43:07 PM(UTC)
Maytag Dryer wont start (Dryer Repair)
by rscottc 5/27/2018 10:49:05 PM(UTC)
maytag dryer wont start (Dryer Repair)
by clavin29 3/1/2014 7:22:21 AM(UTC)
Maytag dryer wont start (Dryer Repair)
by Rich8529 6/25/2012 4:46:37 PM(UTC)
by c strain 1/23/2009 11:27:18 AM(UTC)
