Calamity
#1 Posted : Tuesday, December 25, 2007 8:50:54 AM(UTC)
Calamity
These older ovens are in excellent shape and have been used very little. Heat elements will not go on even though selected temperatures and mode are indicated. Checked for proper voltage and manual reset breakers. Seems problem is with motherboard, no signs of damage or burned contacts. Appreciate any input and to the availability of parts for this oven.
#2 Posted : Tuesday, December 25, 2007 11:51:18 AM(UTC)
The first thing I would check is the high temperature cutout (#18 on the body and deflector bracket break down diagram).
It is resettable. Just push in the red button.
Good luck.
Calamity
#3 Posted : Thursday, December 27, 2007 8:56:08 AM(UTC)
Calamity
Good luck.
Thanks for your response Gene. I did check the high temperature cutouts during my initial troubleshooting. There are two located behind a side panel. Both were in and not tripped. I still think the problem exists in the Main Relay Board. ( I called this a motherboard). Bosch now owns Thermador. Are replacement kits available for this double oven unit?
I notice that Bosch does have control kits that include a relay board and display for later ovens (Bosch part# AP3382408)
I could not locate a relay board on your attached schematics for CT227N8
#4 Posted : Thursday, December 27, 2007 9:13:04 AM(UTC)
The next part I would check is the sail switch or the air interlock switch (#2 on the plenum assembly break down diagram).
This is a normally open switch which should get closed with the air pressure from the blower.
You can bypass this switch for the test purpose.
- The part number for the sail switch is AP2831958
kawfeeman
#5 Posted : Friday, January 25, 2008 6:12:49 AM(UTC)
kawfeeman
would like to know how this worked out ?
Guest (5)
Oven Will not heat to temp. (Oven Repair (including Ranges and Cooktops))
by rtmeek 9/12/2022 12:32:58 PM(UTC)
Frigidaire FEFL79HQA Oven Will Not Heat (Broil or Bake) (Oven Repair (including Ranges and Cooktops))
by Allen_M 5/19/2022 8:57:30 AM(UTC)
Frigidaire - Oven will not heat up but burners work (Oven Repair (including Ranges and Cooktops))
by JohnGuerra 3/18/2020 12:45:12 PM(UTC)
Frigidaire gas oven will not heat (Oven Repair (including Ranges and Cooktops))
by HHG 9/6/2019 11:33:44 AM(UTC)
GE Profile Oven will not heat past 100, broiler works (Oven Repair (including Ranges and Cooktops))
by maribernj 2/16/2016 8:37:13 AM(UTC)
Oven will not heat (Oven Repair (including Ranges and Cooktops))
by couldcareless 11/11/2015 2:05:29 PM(UTC)
by davidwhop 8/31/2014 7:17:47 AM(UTC)
Double Wall Oven will not heat up (Oven Repair (including Ranges and Cooktops))
by jwmingus 11/12/2013 4:25:40 PM(UTC)
Frigidaire Left oven will not heat either element (Oven Repair (including Ranges and Cooktops))
by morang 9/27/2013 5:08:44 PM(UTC)
Thermador sc302t top oven will not heat (Oven Repair (including Ranges and Cooktops))
by bnastasi 6/9/2013 9:01:10 PM(UTC)
Lower and Upper Oven will not heat (Oven Repair (including Ranges and Cooktops))
by Igmike 4/22/2013 5:43:12 AM(UTC)
My Oven will not heat up on bake (Oven Repair (including Ranges and Cooktops))
by missy79 4/3/2013 9:59:06 AM(UTC)
Electrolux dual fuel range oven will not heat (Oven Repair (including Ranges and Cooktops))
by p.andrew 3/19/2013 8:47:44 AM(UTC)
by Pjcibulski 1/29/2013 2:00:44 PM(UTC)
Oven Will Not Heat (Oven Repair (including Ranges and Cooktops))
by badams1214 1/18/2013 12:14:24 PM(UTC)
