Washer won't fill with water. Everything else works fine. Already replaced mixing valve. Will work if I fill from outside source.
Originally Posted by: drtstev Washer won't fill with water. Everything else works fine. Already replaced mixing valve. Will work if I fill from outside source. Can you post the model #? Some of the earlier models with electronic controls (SE1000) had 24 volt water valves. If you put in a 120v valve that would sure stop it from filling.
I can't find the model#. Looked all over the darn thing.
Originally Posted by: drtstev I can't find the model#. Looked all over the darn thing. Is it got a touch pad or is it manual controls? Did you open the dryer door and look there?
Originally Posted by: Frank / APP Team Is it got a touch pad or is it manual controls?
Did you open the dryer door and look there? Looked in dryer door, nothing. Controls are manual. Turn dial that you pull to turn on.
Originally Posted by: drtstev Looked in dryer door, nothing. Controls are manual. Turn dial that you pull to turn on. About the best I can do without a model, is to remove the front panel, and with the help of a volt meter, start back tracking from the water valve. There are a number of parts involved. Some stacks had a fuse in them.
