Ice make all the sudden is making ice but it is starting to fill more water on ice in the tray in the middle of the cycle and water is flowing all over the place. Please help
Took out last night cleaned work fine till today :confused:
Originally Posted by: aploss Ice make all the sudden is making ice but it is starting to fill more water on ice in the tray in the middle of the cycle and water is flowing all over the place. Please help
Took out last night cleaned work fine till today :confused: Try and catch it right after it fills up. Look and see if all the slots for cubes are actually being filled. If the front one or two slots aren't getting water then it can cause the IM to go through a second fill. It has a thermostat which is sensing the front of the mold. If it doesn't warm up upon water fill, and open, it can cause the IM to go through a double fill. Sounds crazy that a underfill can cause a overfill, but it isn't a uncommon scenario. If this happens to be it, you may be looking at a water valve that's going bad. There also should be a adjustment screw on the side of the IM head that you may be able to get enough adjustment out of.
It has a 8 cube wide machine and it freezes all they way but it works than fills than freezes doent dump than fills with water again????
Originally Posted by: aploss It has a 8 cube wide machine and it freezes all they way but it works than fills than freezes doent dump than fills with water again???? So you're saying that while the ice is frozen in the mold, ready to be harvested, all of a sudden the IM calls for more water and another 4.5 oz. comes pouring in? Not a real common scenario for a IM failure. Have you tried moving the rakes(paddles), are they stripped, as in they move around freely? Is it possible the water is just constantly dripping in after it's filled itself, eventually causing a spillover?
Help took the unit out of the fridge completly out and unplugged and left over night and water was frozen all over the place in the morning why would water come out of the spout in the freezer?.:mad:
Originally Posted by: aploss Help took the unit out of the fridge completly out and unplugged and left over night and water was frozen all over the place in the morning why would water come out of the spout in the freezer?.:mad: If water came in without the unit being plugged in, it sure sounds like you've got a bad water valve. It just isn't closing off, and it's letting water come through. Part number: AP4298908
Well guys I put in a new valve, and now when I keep door open and use water it calls for water and it comes out of the drain for the ice maker. So now I am getting water all over HELPPPPPPPPPPPPP:mad:
Originally Posted by: aploss Well guys I put in a new valve, and now when I keep door open and use water it calls for water and it comes out of the drain for the ice maker. So now I am getting water all over HELPPPPPPPPPPPPP:mad: Sounds like you put the wires for the dispenser on the IM solenoid, and the wires for the IM, on dispenser solenoid.
I thought I put back same way so what ones do I change around? the 2 that are close to each other?
Because as of now both im and water disence at same time. I go to get water and im water comes. So If I change around that should take care of problem.
Originally Posted by: aploss I thought I put back same way so what ones do I change around? the 2 that are close to each other?
Because as of now both im and water disence at same time. I go to get water and im water comes. So If I change around that should take care of problem. You've got something mixed up, be it the wiring or the four different plastic lines. The plastic line coming off the main valve that your house plumbing hooks to should be going to the water filter. A line from the filter should then be coming back to the single connection to the dual valve. Then one side of the dual valve should go to the IM and the other one should be going to the dispenser. Don't know if it will help or not but on the below link if you look at pg. 11 and 12 it shows a wiring diagram and schematic. They aren't real clear so seeing them may be an issue. Model PLHS269ZDB3
