AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Gas dryer fires gas only once = igniter works AOK
Hot surface igniter works fine. After first cycle of gas and heat, gas never flows even though igniter glows. Leave dryer off for 1 hour; one cycle of gas....flame...heat...flame out. One minute latter, igniter lights but never get gas/flame. Coils measure resistance. Could the gas valve be bad after it heats up the first time of a new cycle?
Appreciate any ideas. Gary
Replace both gas valve coils and your problem will be solved.:) Common problem with that dryer.
Thank you for the reply. I measure resistance in both coils so neither one is open. They get warm to the touch after a starting the dryer. Could the problem be in the valve assembly where the coils open the gas route? Maybe I should replace the entire burner assembly with valve and both coils?
I know you said the coils are fine by a resistance check, but what I am telling you is to replace them!! They are the reason for your problem....NOT THE GAS VALVE!! I have serviced many of these dryers for the problem you described and have fixed the problem inexpensively with replacing the coils. With 18 years experience my wife wife will tell you that I am not wrong very often and she hates me for that reason LOL :D
Originally Posted by: ripleys ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I know you said the coils are fine by a resistance check, but what I am telling you is to replace them!! They are the reason for your problem....NOT THE GAS VALVE!! I have serviced many of these dryers for the problem you described and have fixed the problem inexpensively with replacing the coils. With 18 years experience my wife wife will tell you that I am not wrong very often and she hates me for that reason LOL :D Ordered the replacement coils from AppliancePartsPros and installed them last night. WORKS like new! You know your dyers. Thank you Mr. Ripley for your help. I hope to get another 5 years of service out of this Maytag.
AHHHH another satisfied customer, even though it took me getting mad at you ( LOL) before you would listen!! Glad I could help.
I have exactly the same model# mdg7600aww same exactly problem can you tell me exactly what's the part# for the Gas valve coils? I don't want to get the wrong one.:) Please desperate for help!!!!
AP3094251 is the appliance pros part # The whirlpool (maytag) part # is 279834 Hope that helps.
My Whirlpool is doing the same like this case, my model is LGQ8858HZ0, but do you think is the same problem on my's?:confused:
I am a complete novice, but I'd like to try solving this exactly issue on my Maytag MDG7600AWW. I replaced the fuse (Part #AP285207) earlier today and thought the issue would be resolved. Of course, this followed searching for lint build-up and the like.
Gas coil replacement? As I looked inside and I think I know what you are indicating -- is there a "trick" for getting the coils off? Are they soldered on or is it just the screw?
Dryer Repair
