I've had this dryer for 3 months, and everything seems to work fine, except that it doesn't heat. Anyone? It was working fine until today.
I bought it at a discount appliance store, does that invalidate the manufacturers' warranty? If the warranty is still good then I don't care what the problem is.
The dryer runs on 2 30amp fuses or breakers. One for the motor and one for the heat. First off locate house fuses or breakers and make sure "BOTH" fuses or breakers are good. Just because it runs doesn't mean that both fuses are good!! That's where I would start.:cool:
If neither breaker was tripped, does that mean they're OK, or can one burn out and not trip?
