Dear Sirs, The soap dispenser has a rectifier on it ---- how can I test it??? I do have a VOM w/ diode tester but I do not know how to ust the diode tester section:confused: . I would rather replace the rectifier ( if non-functional) rather than the whole dispenser unit. Thanks, Lew L
Hi Lew, No one service manual has a such diagnosis instructions nor the schematic. Bosch does not sell such parts. My recommendation is to replace the whole dispenser as instructed by the manufacturer. - The part number for the soap dispenser is AP2834000 Gene.
Thanks Gene and others,
Replaced dispenser in about 15 minutes ( thank God for battery powered screwdrivers ). The little printed circuit board did have a burntout resistor. I'll be working hard to find this board and if I can't -- it's off to Radio Shack for the resistor.
Lew
