My dryer was working one day and was not the next day. No heat at all. I looked at the coils and they are complete. I have a multimeter, but I dont know what to test. Any help would be greatly appreciated. Kelso
First check that you have 120v coming to each side of the connection block. Then unplug the machine and open it up. Check the thermostats and thermal fuses for continuity and the heating coil for resistance.
Good luck.
I found that it was the hi temp fuse.
Yep, that'll do it.
Glad you found it and thanks for updating us.
