stove top stopped working after lightning storm . found 50 amp breaker tripped ,reset breaker no help . stove top uses a down draft system ,with ducting going thru concrete floor and vents outside just above ground level. the lightning struck aprox . 500ft from ground level vent . the downdraft and the stove top use a common electrical box with common ground ,stovetop was off during storm . no other appliances or electrical devices were damaged.
what got hit , the display board ,main board or power board? again stove top is totally dead no way to get codes for trouble shooting. wiring is good to power board .
