5 Pages123>»
jayconnor
#1 Posted : Sunday, December 30, 2007 7:15:37 AM(UTC)
jayconnor
Any help greatly appreciated
My Kitchenaid side-by-side icemaker stopped working
Water dispenser in door works fine
Researched this on the net and figured inflow water line was frozen so I got hairdryer and heated up the little black tube where the water comes in (see photo) but didnt work
Dont know where the waterline runs so dont know where else to heat assuming thats the problem and not some thing else
6 months ago similar thing happened but it just started working spontaneously
What to do
Thanks in advance
jayconnor attached the following image(s):
#2 Posted : Sunday, December 30, 2007 8:52:32 PM(UTC)
Hi Jay
Open the freezer door, press in the emitter flaper door (on the left side) to unblock the optics beam and view the diagnostics "status" LED on the right side.
Post you findings and the complete model number of the fridge.
Happy New year!
MLisk
#3 Posted : Friday, January 11, 2008 10:43:44 AM(UTC)
MLisk
I have the same Kitchenaid Frig. about 2.5 years old. Had problems with the Icemaker not ejecting ice from the tray, I found out that the peg on the "timing gear was cracked. After I glued that it never really worked after that even though I couldn't find anything else wrong.
I ordered a whole new unit from you guys and installed it yesterday but it hasn't done anything in last 12 hrs.
The replacement Part Number is W10122502 the tag has 185w-115-60hz IM# mmap 106w10122502 The old unit has 260-115-60hz IM# S 106 626663 om it. It looks like it is a different wattage. Any Suggestions??
Thanks, Matt
thompsam
#4 Posted : Saturday, January 12, 2008 9:28:12 AM(UTC)
thompsam
I have the same problem as jayconner. No ice is being made but water flows just fine from the door. My fridge is a kitchenaid, model # KSRG25FKWH17 . It's about 1 1/2 years old. I've tried the heat the little black rubber water inlet tube with a hairdryer apporach and unfortunately, that seems to have had no efffect. The LED status light is off when the door is opened. When I "unblock the optics beam", the led is stays off.
Any recommendation on a next step to take would be appreciated.
Thanks, Sam
#5 Posted : Tuesday, January 15, 2008 1:20:35 PM(UTC)
Hi Matt,
In order to provide the most accurate advise I need the complete model number of the refrigerator.
#6 Posted : Tuesday, January 15, 2008 1:26:08 PM(UTC)
Hi Sam,
If the ice maker "on-off" switch is in "on" position and the LED is "off", then the problem is a bad optics.
- The part number for the optics kit is AP3137510
MLisk
#7 Posted : Wednesday, January 16, 2008 5:47:22 PM(UTC)
MLisk
Hi Gene,
The Frig Is a Kitchenaid KSRP25FNSS00. The four pronged flat plug that plugs into the icemaker doesn't seem to have the right voltage coming out of it , I measure 5.5 volts Ac and think that it should be 115 volt Ac.
I think that's why neither the old icemaker or the replacement will work.
Do you know where the four prong plug get it's power from? Is it from the main circuit board at the top of the frig side compartment? I looked at it but no obvious burns or defect in the board.
Any help will be greatly appreciated.
Thanks, Matt
#8 Posted : Wednesday, January 16, 2008 6:00:38 PM(UTC)
Hi Matt,
Open the freezer door, press in the emitter flapper door (on the left side) to unblock the optics beam and view the diagnostics "status" LED on the right side.
Did you run this test?
What is the result?
thompsam
#9 Posted : Saturday, January 19, 2008 9:06:26 AM(UTC)
thompsam
Just thought I'd report back what my problem was. Turns out, I needed a new motor module (AP3177342). As it turns out, my wife bought an extended warranty and the module was replaced at no cost. Thanks for trying to help Gene, I appreciate it.
#10 Posted : Saturday, January 19, 2008 12:55:04 PM(UTC)
I'm glad you were able to fix it.
Guest (7)
Kitchenaid icemaker not working (Refrigerator & Freezer Repair)
by gmpfeffer 2/24/2013 1:42:19 PM(UTC)
Kitchenaid Icemaker not working (Refrigerator & Freezer Repair)
by Stekelenburg 12/12/2012 9:55:44 AM(UTC)
kitchenaid icemaker not working (Refrigerator & Freezer Repair)
by Kewoldt 12/3/2011 7:13:17 PM(UTC)
by Dan54 2/28/2011 11:39:01 PM(UTC)
KitchenAid icemaker not working (Refrigerator & Freezer Repair)
by Anilkumar15 12/31/2010 5:44:41 PM(UTC)
by jjjacek 6/5/2010 4:45:22 AM(UTC)
Kitchenaid Icemaker Not Working (Refrigerator & Freezer Repair)
by Doug_dallas 6/8/2009 2:00:59 PM(UTC)
5 Pages123>»
