This may sound like I am really stupid, but I need to replace the lid safety switch on my washer. I purchased the part from Roper, but I am having a heck of a time getting the washer top open...in the past they have always opened along the front edge with the tap of an inserted putty knife. I called Roper and they wouild not tell me how to open the top...go figure. Can anyone slove this mystery? :confused:
Don't try to take the top off..It's changed from the older styles. You need to remove the cabinet. Take the 2 screws out from each side of the console.(they are in 3 different locations) When the screws are out, lightley pull the console to you and it will hinge back.Next, remove the 2 brass "S" clips from both sides, disconnect the connector at the top, now tilt the cabinet forward and off the base. I hope this helps. I believe there is an info. sheet at this site somewhere to show how to do this.Try this link here..wrench http://appliancejunk.com...p?topic=68.msg213#msg213[URL="http://appliancejunk.com/forums/index.php?topic=68.msg213#msg213"][/URL]
Thank you Wrench. The video was helpful, but the part I am replacing is still attached to the top of the machine. Do I have to stand on my head and pinch my fingers to replace it?
