Fireweed
#1 Posted : Wednesday, August 26, 2009 7:53:57 AM(UTC)
Fireweed
I have been erratically getting an error code indicating a keypad/control panel. If the problem continues, I will replace whatever needs replacing. The metal part holding the electronics is 827234. The control panel electronics part # appears to be 8273640. Questions:
1) Would I need to order both the metal housing part and the electronics part together, or could I just order the electronics part?
2) Does the touchpad come with the electronics part?
3) If the touchpad is a separate part, can I peel it off the front of the stove to look under it without damaging anything?
4) If the electronics part is a separate part that I could order and install on my existing metal part, can you help me understand how the electronics part is affixed to the metal? It seems awfully securely fastened, but maybe I just don't understand the fasteners. I am attaching a photos.
THANK YOU!
Fireweed attached the following image(s):
#2 Posted : Wednesday, August 26, 2009 2:26:02 PM(UTC)
The model number you posted does not come up and without correct model number we can not proceed further. Verify and repost the model number.
Fireweed
#3 Posted : Wednesday, August 26, 2009 4:27:46 PM(UTC)
Fireweed
Thank you for your fast reply. My model number is 665.75801000. I am also posting a photograph of the model label that is on the stove. Much appreciation for your attention to my questions.
#4 Posted : Wednesday, August 26, 2009 8:37:24 PM(UTC)
THANK YOU!
1) I'm assuming "the metal housing part" is the control panel (#3 on the diagram). You do not need this part and it is no longer available.
2) & 3) The touch pad, aka a membrane switch sold separate. It is very easy to damage it if you'll try to peel it off.
4) As far as I can see on the diagram, the control board (#12) secured with a few screws (#13) which is pretty standard.
- The control board Part number: AP3180904
- The membrane switch Part number: AP3120635
Guest (5)
