microwave starts beeping when not in use. after disconecting power at fuse box for about an hour unit works fine for a short time. then starts beeping again then keypad will not work. till power shut off.
Hi most likley it is the control board has failed it is in a sense a computer and the data is courpted the control will need to be replaced to fix the problem when you disconected power and reconected it you reset it but due to data courption it will shut down again D.
