3 Pages<123>
Servicer
#11 Posted : Wednesday, October 1, 2008 11:41:19 AM(UTC)
Servicer
From what I can recall, there should be a wire diagram tucked away under the control board. If you find it you can locate the motor which should have the resistances next to it. Using the diagram check the appropriate terminals to see if the reading match what the diagram shows. If so, the motor is OK.
acruzntx
#12 Posted : Saturday, April 18, 2009 12:09:21 PM(UTC)
acruzntx
I am having the same problem and am needing help figuring out the error codes. I did what Servicer mentioned to obtain the error codes but can't figure out what it means. Below is what I got
doing P:01
E:09 C:03
E:20 C:01
D:06 C:01
D:11 C:01
D:10 C:01
D:08 C:01
doing
P:04 E:02
Anyone who can point me to the error code table or be able to interpret it is much appreciated. Thanks.
I have a Bosch nexxt 500 series
alexandr
#13 Posted : Tuesday, August 25, 2009 11:29:57 AM(UTC)
alexandr
Sir,
I have the same problems with my BOSCH washer WFMC3200. It does not spin. Did you find out what was wrong with your washer?
Thanks.
acruzntx
#14 Posted : Tuesday, August 25, 2009 7:51:10 PM(UTC)
acruzntx
Originally Posted by: alexandr Go to Quoted Post
Sir,
Thanks.
Yes I did,. I had to change the motor board similar to what the other guy did. But first check the error codes
What you can do is put
it into a service mode to check for error codes. I'll post the directions below:
4/18/2009 Bosch FL wont spin or agitate - Appli&#8230;
&#8230;appliancepartspros.com/&#8230;/10262-b&#8230; 3/7
#8 (permalink)
1)With unit turned off, press and hold the two buttons to the left of the knob, (Spin Select and Delay - I
think)
2)While holding those buttons, rotate the knob one to the left (Perm. Press Cold)
3)Keep holding the buttons until the display shows a P:01
Now, the way Bosch's test program works is the P:XX is the specific test, and pressing "Start/Pause" will
start that test.
The tests I can recall are as follows:
P:01 - Error Code Recall
p:04 - Spin Test
P:13 - Water Valve(s) Test
P:15 - Drain Test
There are others, but these are the one's I used most ofter, therefor remember.
P:01 - Pressing start will show you an E:01 / C:0X
What this means is the E:XX is the error code and the C:XX indicates the number of times the code has
shown up in the last 8 cycles. Using the spin select button will allow you to scroll through all 24 of the
control errors as well as the motor codes, which are D:XX codes.
So, for example, if you see an E:21 / C:03 this means you unit felt there was too much foam (soap) inside
the unit,
P:04 - Pressing start will cause the door to lock, the drain to kick it and (hopefully) the unit to agitate and go
into a full speed spin. You may see an error code pop up at this point if the unit fails to spin.
P:13 Pressing starts the filling of the bleach cup. Press it a second time and the soap cup will fill with cold
water. Once more and it fills the fabric softener cup. Finally, pressing it a fourth time will fill the soap cup
with hot water. Hitting the spin select will cancel this test.
P:15 Press start and it drains.
So, using the directions above check for error codes and run a spin test. Post up your results and I'll see
what I can make of it.
alexandr
#15 Posted : Tuesday, August 25, 2009 8:11:49 PM(UTC)
alexandr
I did spin test. When I put [FONT='Verdana','sans-serif']P:04 and pressed start - the door was locked, it start drain but the unit did not agitate and did not spin. There is an error code E20. What does it mean?[/FONT]
[FONT='Verdana','sans-serif'][/FONT][FONT='Verdana','sans-serif']Thanks![/FONT]
alexandr
#16 Posted : Tuesday, August 25, 2009 8:13:15 PM(UTC)
alexandr
alexandr
#17 Posted : Thursday, August 27, 2009 6:50:59 PM(UTC)
alexandr
If you have time can you tell me what is it error code E20?
P:04 error code is E20
I checked Motor resistence:
Contact 4 to 5 it should be 120.0-180.0 and it has 320.0
Contact 6 to 7 It should be 1.2-1.8 and it has 3.2
Contact 7 to 8 it should be 1.2-1.8 and it has 3.2
Contact 6 to 8 it should be 1.2-1.8 and it has 3.2
Does that mean the Motor is bad or it is main bourd?
Thank you.
Alexandr.
smedovnikov
#18 Posted : Tuesday, October 27, 2009 8:32:32 AM(UTC)
smedovnikov
Hi,
my Bosch washer does not spin. I ran diagnostic test and it gives error code F20.
Is anybody knows what F20 means?
Thanks,
Sasha.
alexandr
#19 Posted : Wednesday, October 28, 2009 1:11:36 PM(UTC)
alexandr
Hello
I have the same error Code F20. I do not know what it is and nobody helped me so far. If you find out more please let me know.
Alexandr.
smedovnikov
#20 Posted : Wednesday, October 28, 2009 1:23:42 PM(UTC)
smedovnikov
Repairmen just checked my washer and he said that I have to replace Drive Motor Control Board. The price would $410. Ooops. I talked to Bosch they said if I buy from them it will cost $206.90 + tax. I am going to check it tonight if I can locate the problem without replacing the whole unit.
Sasha.
Guest (8)
3 Pages<123>
