nextel8
#1 Posted : Saturday, August 22, 2009 11:08:54 AM(UTC)
nextel8
Help,
I started to dry a load of laundry. It was not a large load and when I started the dryer I noticed that there was no sound of clothes tumbling for them to dry.
I opened the door and sure enough the clothes had not moved. The heating element works fine. The inside drum does not seem to be rotating? What does that mean?
sidfink43
#2 Posted : Sunday, August 23, 2009 10:15:25 AM(UTC)
sidfink43
If your motor is turning it means your belt is broken, not an uncommon event.
I think on this model you can flip open the top by releasing two clips by placing a putty knife or screw drive in the gap between the front and top near the edges. The top should flip up, and you will notice the absence of a belt around the drum.
