mariop11
#1 Posted : Wednesday, January 16, 2008 3:26:28 PM(UTC)
mariop11
At first there was no water in the spin cycle. Now there is no water in the wash cycle. How do you get into the controls?
Thanks.
#2 Posted : Thursday, January 17, 2008 12:00:12 PM(UTC)
There is no hot or cold water, or there is no water at all?
mariop11
#3 Posted : Thursday, January 17, 2008 12:16:01 PM(UTC)
mariop11
Gene, I can get water to the first cycle only. After the spin cycle the aggitator turns on but no water. I tried to reset the cycles with the control but no water. I cleaned the screens and water flows to the washer.
Thanks,
Mario
#4 Posted : Thursday, January 17, 2008 1:32:16 PM(UTC)
The first thing I would check is continuity across the "V" & "T" terminals on the water level switch at the time when the agitator turns without water inside.
Post your findings.
sloandenman
#5 Posted : Tuesday, March 25, 2008 5:29:07 AM(UTC)
sloandenman
I Have A Kenmore Washer Model #110. It Works Fine Except Recently It Stopped Dispensing Hot Water, Or Just Tricks Out Very Slowly. Whats Wrong.? And What Replacement Part Do I Need And What Is The Part #. Thanks --dennis
sloandenman
#6 Posted : Tuesday, March 25, 2008 5:30:20 AM(UTC)
sloandenman
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
#7 Posted : Tuesday, March 25, 2008 7:46:28 AM(UTC)
Most likely the problem is a bad water inlet valve. In order to provide the right part number I need the complete model number of the washer. "110" is just a prefix.
