My dryer will run for a week or so and then it won't start. Press the start button and the timer will tick if it is in any position other than off.
What should I do?
Is it completely dead or it's an intermittent?
It does not run right now. I tested the timer by checking the power wires with a ohm meter. Checked ok.
The timer and thermal fuse check ok.
Check the wires to the motor and resistance across the motor terminals where the white and the blue wires coming to the motor.
Post your findings.
