My washer fills up washes then skips the rinse cycle and spins only the water stays in the tub. Then when done water is over flowing everywhere cause it won't drain. If I take the hose out of the drain in the wall and drain into a bucket that's on the floor it drains out in spin cycle. Trying to figure out what to fix.
Remove the front panel and check the pump and the drain hoses for any foreign objects. If this is not the issue - replace the drain pump. - The part number for the drain pump is AP3873050 Gene.
