lindi
#1 Posted : Tuesday, January 15, 2008 9:54:51 AM(UTC)
lindi
my oven flashes f 10 code after preheat and turns off
#2 Posted : Tuesday, January 15, 2008 5:24:26 PM(UTC)
Hi Lindi,
In order to provide the most accurate advise I need the complete model number of the oven.
lindi
#3 Posted : Wednesday, January 16, 2008 7:51:52 AM(UTC)
lindi
model FEF366DCE
#4 Posted : Wednesday, January 16, 2008 10:00:28 AM(UTC)
Hi Lindi,
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It suppose to be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
- The part number for the oven temperature probe is AP3704441
- The part number for the EOC is AP3776874
- The part number for the EOC overlay is AP3778486
Good luck.
F10 Error Code; Runaway Temperature (Oven Repair (including Ranges and Cooktops))
by Keith Hocky 10/18/2010 4:11:10 PM(UTC)
What does an F10 Error Code Mean? (Oven Repair (including Ranges and Cooktops))
by gwest2010 1/19/2010 6:38:10 AM(UTC)
