Montana123
#1 Posted : Thursday, August 13, 2009 8:54:17 PM(UTC)
Montana123
Starts to fill for about 10 to 15 sec. and everything shuts off. If you start again same thing happens. Please advice!
sidfink43
#2 Posted : Friday, August 14, 2009 3:35:42 PM(UTC)
sidfink43
This is probably your control board. The control board in this model can be damaged by problems with the wax motors that lock the door and may operate the dispenser assembly,
Here is the service manual. I have to tell you that this is a first generation Neptune and one of the most troubled machines ever built, and this may well be the time for you to replace it.
Good luck.
http://www.servicematters.com/m...ibrary/docs/16010061.pdf
Guest (6)
Maytag Neptune clicks/creaks/groans at low spin speeds but not at high speeds (Washer Repair)
by fixitboy 7/3/2024 1:06:24 PM(UTC)
Maytag Neptune mah9700a won't drain ...(locking issue?) (Washer Repair)
by Mr.Petes 8/4/2023 4:55:48 AM(UTC)
Maytag Neptune wont high spin under load (Washer Repair)
by jim20j 2/24/2023 9:23:15 AM(UTC)
Maytag Neptune Stacklable (Washer Repair)
by johnafoy@yahoo.com 2/7/2023 11:34:24 AM(UTC)
MAYTAG NEPTUNE STACKED - GAS - NOT SPINNING (Washer Repair)
by ccalderon70 1/9/2023 9:09:40 AM(UTC)
Lr code on my Maytag Neptune Front Load Washer (Washer Repair)
by Guest 11/19/2022 9:53:55 AM(UTC)
Maytag Neptune Front Load Washer “do” code (Washer Repair)
by Guest 12/25/2021 2:22:33 PM(UTC)
maytag neptune MAH21PD tumbles during spin (Washer Repair)
by joedonovan 11/22/2021 4:27:39 PM(UTC)
maytag neptune MAH21PD (Washer Repair)
by Guest 11/22/2021 4:23:11 PM(UTC)
Maytag Neptune MAH5500AWW (Washer Repair)
by Bubdad1 4/19/2021 4:49:41 AM(UTC)
Maytag Neptune DC (Drying Center) gas dryer mcg8000aww Flame not staying on (Dryer Repair)
by chanash 12/15/2020 3:00:11 PM(UTC)
maytag neptune motor spins too fast (Washer Repair)
by jbmur 11/27/2020 7:25:55 PM(UTC)
Maytag Neptune MAH8700 Repair (Control Board) (Washer Repair)
by kicaza 11/17/2020 9:45:19 AM(UTC)
Maytag Neptune washer stops and won't unlock (Washer Repair)
by dctaz37 9/13/2020 5:18:38 PM(UTC)
Maytag Neptune runs cold and hot but not warm (Washer Repair)
by mikecinmaine 7/25/2020 6:32:28 AM(UTC)
