vterm
#1 Posted : Friday, August 14, 2009 10:26:45 AM(UTC)
vterm
I have a GE Profile bottom freezer refrigerator that I bought in 2007. Model PFS22SISBSS, Serial #AM053511. The freezer temperature rises intermittently, and can range from -2 deg C to +19 deg C. My wife has suggested that the higher temperature occurs when she has the freezer open for loading up groceries. However, I have seen occasions when it has gone up to +10 deg C without opening the freezer door.
I have seen a number of posts on various forums where people have had problems with the motherboard. I have motherboard WKKT Model #0158-04-03A. GEA Part #200D4880G015. (I had called GE Consumer Affairs and was told that the part # is WR5510942. Apparently, the customer service rep said there was no recall for my motherboard.)
I checked J2 pin #3 to #4 (fan speed); voltage is 12.7 VDC (good). J2 Pin #3 to #8 is 13.5VDC (good). However, J2 pin #1 to #3 (evaporator motor) is 5.3VDC instead of 6.3 VDC, and J2 pin #5 to #8 is 8.1VDC instead of 13.4 VDC.
I had problems checking resistance on thermistors on J1 pin 1 to pin 5, but voltages were 2.4 to 3.6 vs the 2.8 to 3.5 VDC.
Is there really a problem here? Do I need to change the evaporator thermistor and the motherboard?
Any suggestions would be appreciated.
Here is the GE diagram that I used.
Thanks.
File Attachment(s):
GE Board Diagram.pdf (157kb) downloaded 42 time(s).
#2 Posted : Friday, August 14, 2009 1:02:31 PM(UTC)
Quote:
...The freezer temperature rises intermittently, and can range from -2 deg C to +19 deg C...
If -2°C is the lowest temperature in the freezer then there is a problem with the sealed (cooling) system. Normal freezer temperature suppose to be about 0°F which is equal to -18°C.
If this is not a mistyping then you have to call GE for the warranty service on the sealed system which should be guaranteed for 5 years.
Here are the breakdown diagrams and Replacement parts for GE PFS22SISBSS | AppliancePartsPros.com
vterm
#3 Posted : Friday, August 14, 2009 1:16:16 PM(UTC)
vterm
Sorry. It's a typo. It should be F not C.
