i change the coupling onthe machine after that was making noise like a ballbearing is broke inside try and smell burning try to check out and now dont trow water or turn in any cycle and make a humming noise
Take off the motor and check to see if you did not press the coupling too close to the transmission, causing the motor to lock up against the transmission shaft that holds the coupling.
thanks i will look in to that but the washer dont even get water
You may have blown a fuse or tripped a breaker in the service box in the house.
is not i fuse the motor make a humming noise but don't star or trow water into the washer
the washer agitated but don't pump/drain the water itest the lid and is ok and the switch to only make a humming noise thanks
I would pull the pump and look for a sock stuck in there.
thanks i will do but went is spinnig make noise like a ball bearing is broke inside
the machine is working until gets hot and stop this happen after i change the coupling and have a burn smell wat can be the problem thanks
the washer work until gets hot them stop and have a smell of burning this happen after i change the coupling that engage the motor to transmission thanks
