2 Pages12>
arkie102
#1 Posted : Thursday, August 13, 2009 5:35:27 PM(UTC)
arkie102
Spin cycle to slow in all wash/spin speed selections. Tub empties ok but at end of cycle cloths are still wet enough to ring a bit of water. At the end of the cycle I can not here the normal brake action. I have changed the belt. Turning the pully clockwise oscilates the agitator and turning the pully counter clockwise the pully turns. I have also changed the Wash/spin speed switch. If the problem may be the Brake can it be adjusted, If so how.
I have checke all the possible things ,kinked hose ,tub seal, etc:confused:
Wes
boshman
#2 Posted : Thursday, August 13, 2009 9:12:23 PM(UTC)
boshman
the clothes is still wet because the basket is not spinning fast enough. do this put it in spin mode for say 4 minutes. stop the washer if the brake stator is hot u got a bad pulley. replace the pulley since it is not pushing the spring brake rotor far enough to allow free basket drive rotation.
richappy
#3 Posted : Friday, August 14, 2009 1:39:40 AM(UTC)
richappy
I would shine a light in the spin basket to look for something stuck in the tub.
If ok, you might have bad spin bearings, pull front cover and check.
arkie102
#4 Posted : Friday, August 14, 2009 12:58:05 PM(UTC)
arkie102
nothing stuck in tub. I pulled front panel all I see is the motor, pump and Agitator shaft which is a sealed unit which must be connected to the main pully. Nothing smoking or hot on unit.:confused:
wes
richappy
#5 Posted : Friday, August 14, 2009 2:16:11 PM(UTC)
richappy
Any dirty water coming out of the bottom of the tub.
arkie102
#6 Posted : Friday, August 14, 2009 3:20:57 PM(UTC)
arkie102
No.
If the transmission is bad , would the washer still agitate but cause the washer to spin solw.:confused:
wes
arkie102
#7 Posted : Tuesday, August 18, 2009 4:05:31 PM(UTC)
arkie102
Originally Posted by: arkie102 Go to Quoted Post
No.
wes
Would appreciate a reply before I replace transsmission.:confused:Wes
richappy
#8 Posted : Wednesday, August 19, 2009 12:28:29 AM(UTC)
richappy
Turn the tranny pulley in the spin direction. If the tranny will not spin, you need a new pulley with thrust washers.
richappy
#9 Posted : Wednesday, August 19, 2009 4:16:16 PM(UTC)
richappy
If you see white shavings under the washer, you have a bad snubber. Post results.
arkie102
#10 Posted : Tuesday, August 25, 2009 10:49:59 AM(UTC)
arkie102
Wes
UPDATE: Problem solved. Transmission replaced now works fine.Washer less than three years old and only had 1yr warranty. I was lucky Maytag sold me the transmission for 50% off. Thanks for you help. I will add that it is a costly repair parts and labor. A new transmission $144.00 shipping and handling/labor $150/service charge$65.00:mad: :)
Wes
2 Pages12>
