vickie
#1 Posted : Sunday, January 13, 2008 6:39:49 PM(UTC)
vickie
Here's my situation--while using unit, it tripped the breaker. Resetting the breaker , the unit turned back on but it couldn't advance to the next cycle. Removing control panel, notice a triad was burned. i ordered the new board from appliancepartspros and installed. Reconnected everything and tried unit. It wouldn't even turn on. I tried to reinstall old old board(bec. that the unit was at least turning on), but same result. The circuit from the box is good bec my cooktop shares it. The door latch switch seems to be locking in place. Big problem is I can't find my owners manual and I am having trouble getting a pdf of it. Any suggestions? Thanks!!!!
richappy
#2 Posted : Monday, January 14, 2008 1:51:16 AM(UTC)
richappy
Look for the service data sheet under the kick panel and check your module wiring per the schematic, probably wired wrong.
