klsandecs
#1 Posted : Tuesday, January 8, 2008 3:12:56 PM(UTC)
klsandecs
I have a Kenmore Elite Sensor Smart electric dryer. The dryer shuts off before the clothes are dry while using the auto-mosture sensor setting. The tech sheet that came with the dryer has 5 different test to preform. These tests indicate that the electronic control panel needs replaced. I have installed a new one. The problem still exists. The exhaust ducts are clear. Does anyone know what my problem could be? You help would be greatly appreciated. Ken.:confused:
#2 Posted : Wednesday, January 9, 2008 12:07:20 PM(UTC)
Did you run the moister sensor test as described in the tech sheet (test# 4)?
klsandecs
#3 Posted : Wednesday, January 9, 2008 2:01:00 PM(UTC)
klsandecs
Gene, Thanks for replying. i completed all seven tests in the Tech sheet. The diagnostic test, the only difference is when the "Start" pad is pushed, a code of "09" is displayed and the dryer starts. Test 3, test 3a, test 3b, test 3c, test 4, and test 5 all pass or check good. this code "09" must mean something.
#4 Posted : Wednesday, January 9, 2008 4:04:43 PM(UTC)
I do not know what the error code "09" means. Unfortunately this is beyond my expertise.
Maybe somebody else on the forum can help you better.
