jmoar
#1 Posted : Monday, July 27, 2009 1:03:22 PM(UTC)
jmoar
My parents have a Bosh dishwasher in a home they just purchased that won't quit beeping every so many minutes after the dishes are clean. Is there a way to shut the alarm off? i'm assuming there has to be, but I can't figure it out.
PLEASE help!
thanks.
It's model SHU9925uc/12
#2 Posted : Tuesday, July 28, 2009 12:10:14 PM(UTC)
You can stop it by turning off the "on-off switch". If there are any other options then it should be written in the User manual.
Here are the breakdown diagrams and Replacement parts for BOSCH SHU9925 UC/12 (FD 8003-) | AppliancePartsPros.com
jmoar
#3 Posted : Tuesday, July 28, 2009 3:19:10 PM(UTC)
jmoar
Thanks. Does that stop it from beeping completely or just when it finishes. they do not want it to "ever" beep if possible.
#4 Posted : Tuesday, July 28, 2009 7:55:44 PM(UTC)
When cycle is done it beeps to let you know about it. As long as the "on-off" switch is in "off" position there is no power to the dishwasher controls.
jmoar
#5 Posted : Wednesday, July 29, 2009 8:02:31 AM(UTC)
jmoar
They tried to turn the power off, but as you said there is no power to the controls so the dishwasher cannot be run. We're, therefore, concluding that there is no way to stop the beeping at the end of the cycle. The problem is they like to run the dishwasher and then go to bed. They don't want to wake up, get out of bed and turn the "Beeping" off. they just don't want it to beep in the first place.
Thanks for the help anyhow. Please correct me if we're wrong!
#6 Posted : Wednesday, July 29, 2009 12:14:31 PM(UTC)
You can find the instructions in the Use and Care manual.
zill
#7 Posted : Tuesday, April 6, 2010 9:18:25 AM(UTC)
zill
Hey Gene,
To follow up on my Bosch Dishwasher I am getting two error codes a Reg Wash and Delicate/Econo buttons flash after a diagnostic run.
The machine will not turn on.
I replaced the control module - no affect.
Any suggestions from the MAN?
#8 Posted : Tuesday, April 6, 2010 11:21:53 AM(UTC)
How did you run the test?
Did you check the on-off switch and the micro switches on the door latch for continuity?
zill
#9 Posted : Tuesday, April 6, 2010 11:45:50 AM(UTC)
zill
Hey Gene,
Thanks for getting back to me.
The test was run as described in the Bosch trouble shooting manual.
I did not test continuity of the on/off or micro switches.
Is there a pdf on running those tests?
Will.
#10 Posted : Tuesday, April 6, 2010 7:22:30 PM(UTC)
Will,
It says exactly in the troubleshooting manual (page 35), provided by Harold G. in one of our previous threads http://forum.appliancepartspros...troubleshoot-manual.html, what such diagnostic result means and which parts and how have to be checked.
Here are the breakdown diagrams and Fascia panel replacement parts for Bosch SHU9925 UC/12 (FD 8003-) | AppliancePartsPros.com
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
