My oven heats and cooks for a while then it absolutely shuts down . There is nothing lite on the display and no buttons respond, the light in the oven works. After a while the clock will flash like a power failure, but when I reset the controls it goes blank again then I wait to let it cool down and reset and it will cook for awhile again. There has been some sort of code flash but so quickly I could not tell what it was, one time I had 8's across the display briefly. Any suggestions other than a service call? Thanks
Hi Joy
Most likely the problem with your oven is a bad control board.
To find the right part number I need one more digit in the model number (between "A" and "B").
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi Joy
Gene. THANK YOU SO VERY MUCH FOR YOUR RESPONSE. MODEL NUMBER IS JKP15BOA1BB
Hi Joy, The part number for the control board is AP3189149 Good luck. Gene.
