I have a kenmore elec dryer bought mid 90's from what I have read I think I have a bad motor, (runs a while, has a rumble like sound from the motor area then shuts off - it had been squeaking a little also, when taken apart if you spin the motor with belt off you hear a litttle metalic squeak in one area while it turns by hand. How do i get the old motor out? one end drives the belt, the other goes into the blower fan and the fan has a square hole in the middle of the shaft?
i too have a dryer that runs for a while then shuts off. if you try to restart the unit the motoe just hums and if to many attempts are made the motor doesnt even hum. what gives ?
Originally Posted by: RickP ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have a kenmore elec dryer bought mid 90's from what I have read I think I have a bad motor, (runs a while, has a rumble like sound from the motor area then shuts off - it had been squeaking a little also, when taken apart if you spin the motor with belt off you hear a litttle metalic squeak in one area while it turns by hand. How do i get the old motor out? one end drives the belt, the other goes into the blower fan and the fan has a square hole in the middle of the shaft? My motor is gone and I have the front bottom panel off. I am trying to figure out how to disconnect and replace the motor as well. I already bought the motor for $128.
