This unit cycles on in the a/c mode, gets down to 78 degrees, then the compressor goes off, even though the thermostat is set to 61. Must be restarted manually. Drain tray is empty, filter has been changed. Outside vent in place. It will restart, bring the temp down to 78, then cycle off again.
Sounds like the thermostat is bad.
