bhacker
#1 Posted : Friday, July 17, 2009 3:58:44 AM(UTC)
bhacker
My dishwasher stops about mid cycle. If I manually advance the timer, it will finish the cycle. However, the drying cycle seems to finish faster than normal and it doesn't get the dishes dry.
#2 Posted : Friday, July 17, 2009 3:18:59 PM(UTC)
Views messages in topic : 27,455
I would check the thermostat (#29 on the diagram) and the heating element for continuity.
- The thermostat Part number: AP2109201
- The heating element Part number: AP4424048
bhacker
#3 Posted : Saturday, July 18, 2009 3:43:21 AM(UTC)
bhacker
Thanks Gene. I'll check them out and let you know.
Bob
bhacker
#4 Posted : Monday, July 20, 2009 1:52:49 PM(UTC)
bhacker
I checked the element and got 13ohms. Isn't that fairly normal?
The thermostat reads just over 1k ohm. Does this mean it's good or bad?
Thanks,
Bob
#5 Posted : Monday, July 20, 2009 1:56:17 PM(UTC)
Bob,
Looks like the thermostat is the culprit. Normally it should be close to 0 Ohms.
bhacker
#6 Posted : Monday, July 20, 2009 2:03:50 PM(UTC)
bhacker
I spoke too soon. I can't find the thermostat on the diagram. The one I did find in the parts list, had a different part number than the one you gave me. I ohmed out a switch in the control panel. Where is the thermostat?
bhacker
#7 Posted : Monday, July 20, 2009 3:08:51 PM(UTC)
bhacker
I found the thermostat. It is open. I'll order a new one.
#8 Posted : Monday, July 20, 2009 7:54:15 PM(UTC)
Keep us posted.
