My Spacemaker HVM1540 microwave turntable runs when the microwave isn't in use. I noticed this a few days ago. It seems to run all the time. I'm afraid the motor is going to burn out or it will overheat and cause a fire. Its only been in use for a little over a year and isn't heavily used. I tried unplugging, turning the turntable on/off button to off then on again a few times, running the microwave, and clearing/cancelling. It will stop when the door is opened, but runs once the door is shut. For now I have it unplugged. Very strange. I tried the GE site but no help. What do you suggest? Thanks in advance.
Sounds like either a bad switch or board relay; or a short somewhere in the turntable motor circuit.
You have been a member since:: 7/14/2009(UTC) Posts: 2
If your microwave is operating without user interface, check out the national class action lawsuit filed against GE. Go to Home for more information.
