shlomo
#1 Posted : Monday, November 3, 2008 3:30:35 PM(UTC)
shlomo
I have a GE model # GSS25JFPAWW that is 4 years old.
The ice maker works but the water dispensr does not.
I changed the waver valve assembly PN AP3192626 and have 120 vac at the solenoid.
The water reservoir - a coil of plastic pipe - is not frozen.
When I disconnect the plastic pipe at the bottom of the hinge/door connector splice and hit the water dispenser switch - I get a flow of water.
How do I replace and/or fix this now?
Thanks,
Rob
#2 Posted : Tuesday, November 4, 2008 12:54:13 PM(UTC)
Hi Rob,
Sounds like the water line inside the freezer door is frozen up. Did you measure the temperature in the freezer? If it's bellow 0°F then you have to adjust the temperature setting and wait a few days. If it would not help then the door liner has to be removed to defrost the water line.
abadfish66
#3 Posted : Tuesday, November 4, 2008 1:07:16 PM(UTC)
abadfish66
GE has a heater kit that addresses this issue. Here is that part you need....Part Details - GE DISPENSER WATER TUBE, part number: WR49X10173
shlomo
#4 Posted : Tuesday, November 4, 2008 1:41:54 PM(UTC)
shlomo
Gene,
Abadfish66,
Thanks much for your input.
In less than a day - turning down the freezer thawed the line and allowed water flow - seems too fast but I'm not complaining.
Thanks again -
Rob
dnl_em
#5 Posted : Friday, November 7, 2008 12:20:56 PM(UTC)
dnl_em
Do you have the instructions for installing the water tube heater WR46X10173?
abadfish66
#6 Posted : Friday, November 7, 2008 12:31:07 PM(UTC)
abadfish66
It's WR49x10173, and The instructions are included with the part. I personally have not put one in yet, but heard it's pretty easy.
dnl_em
#7 Posted : Monday, November 17, 2008 6:59:23 AM(UTC)
dnl_em
I replaced it this weekend. It was really easy.
Thanks for your help.
dnl_em
#8 Posted : Monday, July 13, 2009 10:56:29 AM(UTC)
dnl_em
After about 3-4 months, the water tube froze up again. I had read that some have tape insulation on the inside of the freezer door to correct this.
Thinking that this might not look too good, I drilled a 1 1/2 in. hole in the inside of the door at the level where the water tube should be exiting out of the outside of the door. (Just under the ice dispenser chute.)
I dug out the insulation around the water tube, and stuffed it with new foam insulation that I got from some packing material. I plugged the hole with a plastic plug that I got at the local Hardware store.
Let's see if this works any better. So far, so good.
woodchuckie
#9 Posted : Monday, July 13, 2009 12:49:44 PM(UTC)
woodchuckie
So the heater didn't work. That's the kind of thing we have to do to get by these days. Good idea.
Ge Water dispenser not working (Refrigerator & Freezer Repair)
by Superiorbuilt 11/14/2008 10:23:39 AM(UTC)
