Bob Mutersbaugh
#1 Posted : Thursday, January 3, 2008 9:30:21 AM(UTC)
Bob Mutersbaugh
My Roper washing machine is leaking water continually. It is like a drip. Could this be one of the water connections to the water pump?
How do I remove the cover? I cannot figure out how to get control panel off.
misterfixall
#2 Posted : Thursday, January 3, 2008 3:01:07 PM(UTC)
misterfixall
is the leak coming from front centre.if so it may be pump
Thesodfather
#3 Posted : Tuesday, March 4, 2008 6:40:49 AM(UTC)
Thesodfather
I also have a Roper washing machine and need to know how to take the cover off. How do you get to the pump to replace it?
My model # is RAS7233Q0
Thanks in advance
misterfixall
#4 Posted : Tuesday, March 4, 2008 7:01:14 AM(UTC)
misterfixall
behind control panel on either side there are 2 screws .once they are removed, you pull the control panel forward +up+lean back. now you will see 2 brass coulered long clips on either side.slip a screwdriver under clip and pull forward +up. remove. there is a small wiring harness towards right attatached to cabinet, pull apart , now lift up on lid ,put hand on cabinet under lid and pull forward on cabinet ,put aside. at bottom you will see plastic pump wth 2 hoses held down by 2 clips ,remove with slot screwdriver.pull pump off, hopefully pump is not rusted on. if so you might have to cut pump off . remove hoses from pump. good luck
Thesodfather
#5 Posted : Tuesday, March 4, 2008 10:45:11 AM(UTC)
Thesodfather
Thanks That is just what i needed.
James
Front Loader washing machine will not fill. E5E error code. (Washer Repair)
by jjuly 7/3/2024 12:25:33 PM(UTC)
GE Top Loader Washing Machine Leaking from bottom (Washer Repair)
by Guest 6/13/2024 9:46:30 AM(UTC)
whirlpool washing machine model wtw57esvw0 (Washer Repair)
by Guest 5/7/2024 7:57:17 AM(UTC)
Help! Washing machine on repeat rinse cycle (Washer Repair)
by cali.poppy 4/29/2024 9:08:28 AM(UTC)
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Stem question about Naytag 2-belt washing machine (Washer Repair)
by Hotrodjohn71 1/2/2024 7:50:48 AM(UTC)
Maytag Oasis HE Washing Machine (Washer Repair)
by Guest 12/8/2023 12:55:45 PM(UTC)
Whirlpool Washing Machine won't start/fill (Washer Repair)
by greekguy7 12/8/2023 4:53:34 AM(UTC)
whirlpool model wtw7300dw2 washing machine (Washer Repair)
by Guest 11/8/2023 9:27:17 AM(UTC)
MVWB965HC0 Washing Machine - Need Service Manual or Video to Replace Touchpad and Control Assembl (Washer Repair)
by Guest 10/30/2023 8:11:10 PM(UTC)
Best vintage, American made washing machines (Washer Repair)
by Guest 10/30/2023 5:27:34 AM(UTC)
Washing machine not washing clothes properly (Washer Repair)
by Guest 9/20/2023 11:56:24 AM(UTC)
Washing Machine fill with water but will not spin, rinse or agitate. (Washer Repair)
by jmaiso 9/1/2023 7:04:07 AM(UTC)
Washing machine do not complete the cycle (Washer Repair)
by Guest 8/16/2023 10:02:15 AM(UTC)
Mayag washing machine - possibly locked motor? (Washer Repair)
by crp0499 5/19/2023 3:02:19 AM(UTC)
