JoshD
#1 Posted : Friday, July 10, 2009 8:27:09 AM(UTC)
JoshD
hi all, i have an older Goodman furnace in a home i just moved into. the blower motor was squeaking a lot, and then just Monday my wife got home from work and the whole house smelled of electrical burn smell. i got home to discover the blower motor very hot and not working. i removed the squirrel cage and removed the motor and had it tested. the motor was junk so i replaced the motor. got everything installed and electrical hooked up and turned the unit on. presto the motor worked sweet right?.... not so much, after about 3-5 minutes the same smell was back so i immediately shut the power to the unit off. felt the motor it was hot again:(:confused:.....i am at a lose of where to go next, any help and guidance is more than welcome and very appreciated, thank you in advance.
-JoshD-
ioane/tech
#2 Posted : Tuesday, July 28, 2009 3:49:31 PM(UTC)
ioane/tech
are you still having the same prob?...do you have the electrical wiring for your motor?..if so can you type it out and show it ,may be the electrical wiring is incorrect
