smanager
#1 Posted : Thursday, January 3, 2008 11:35:55 AM(UTC)
smanager
Not only does the oven not work but niether does the broiler. I think I need a part that is common to both the broiler and the oven. Could both igniters be bad at the same time? I checked but no error code. The model number is SF362LXSY0.
misterfixall
#2 Posted : Thursday, January 3, 2008 2:58:20 PM(UTC)
misterfixall
it may be control board.does ignitors glow?
smanager
#3 Posted : Thursday, January 3, 2008 3:34:26 PM(UTC)
smanager
No they do not glow
misterfixall
#4 Posted : Thursday, January 3, 2008 4:24:32 PM(UTC)
misterfixall
were both bake +broil working +both stopped working at same time?if so check for 110 volts coming to safety valve.or remove wires and check for continuity across contactson valve ,could terminal b+c , if no power of 110 volts it may be board, if there is power it may be valve.there sholud be continuity across b+c
smanager
#5 Posted : Thursday, January 3, 2008 4:34:34 PM(UTC)
smanager
They were both working at one time not sure of they both stopped at the same time. Was baking and swtiched to broil and broil did not work and turned back to bake and that did not work now neither work.
smanager
#6 Posted : Thursday, January 10, 2008 7:28:55 PM(UTC)
smanager
It was not the board, I replaced it and same thing so must be the safety valve right
Guest (8)
