addictedtoboost
#1 Posted : Sunday, June 21, 2009 6:03:56 AM(UTC)
addictedtoboost
Hello All,
New here, I am a Car guy, hence the user name.
My microwave started sparking and burned a hole through what is listed as a Canopy, Mica, part number 1475 covers the microwave emitter with 1 screw inside on right of interior.
A, is this common?
B, What causes this and anything to be concerned about?
C, Should I just replace it and move on or is there another problem?
Also about 1 year after installing this microwave, the interior bulb blew out, I have not been able to find it listed in the parts schematics, the closest I found was called a holder 1207, does it use the halogen bulb listed as 282, also used underneath the microwave?
How difficult is it to gain access to replace this bulb?
Ted.
addictedtoboost
#2 Posted : Tuesday, June 23, 2009 7:28:19 AM(UTC)
addictedtoboost
3 days, 29 veiws, and no responses, Is there anyone here that can help me?
Nancy_GE
#3 Posted : Thursday, July 9, 2009 11:57:22 AM(UTC)
Nancy_GE
Ted: PLEASE disconnect the microwave and read the ************
addictedtoboost
#4 Posted : Thursday, July 9, 2009 12:32:57 PM(UTC)
addictedtoboost
Originally Posted by: Nancy_GE Go to Quoted Post
Ted: PLEASE disconnect the microwave and read the ********. This is no small problem and more common than you realize!
I don't answer to ambulance chasers, get a life.
I am happy to report I replaced the Mica panel and my microwave works perfect.
food stains get extremely hot and eat away at the mica and cause hot spots, I would recommend replacing the panel if it gets a stain on it that normal washing will not remove.
Thanks for all the quick and accurate responses.:rolleyes:
