Steve T
#1 Posted : Thursday, July 9, 2009 7:32:03 AM(UTC)
Steve T
Hi,
My Kenmore dryer will not heat up. The dryer works great otherwise. Can you help me with this problem?
Thanks,
#2 Posted : Thursday, July 9, 2009 3:10:38 PM(UTC)
Steve,
The first thing I would do is check if there is 240 VAC to the dryer. The heater need 240 VAC while 120 VAC is good enough for the motor and the timer.
If there is nothing wrong then perform the troubleshooting as described in the Service manual.
Post the results and we will help you with the correct part numbers.
Dryer will not heat up (Dryer Repair)
by kpholler 12/2/2014 3:42:57 PM(UTC)
Gas dryer will not heat up (Dryer Repair)
by Ahhnother8 10/9/2014 8:16:39 PM(UTC)
Maytag Centennial dryer will not heat up (Dryer Repair)
by 1hkfan 10/31/2012 6:51:34 PM(UTC)
Dryer will not Heat up (Dryer Repair)
Belarus jasmineblue27 8/19/2012 12:56:43 PM(UTC)
Dryer will not heat up consistently (Dryer Repair)
by GPDIY 1/4/2012 5:21:02 AM(UTC)
Electric Dryer will not heat up (Dryer Repair)
by varn99 6/2/2011 3:26:17 PM(UTC)
by ray2 5/13/2011 7:10:58 AM(UTC)
by Raljac63 2/10/2010 7:15:09 AM(UTC)
Whirlpool Kirkland Gas Dryer Will Not Heat Up (Dryer Repair)
by LITTLE RED ROOSTER 1/29/2010 9:11:39 AM(UTC)
Kenmore Dryer Will Not Heat Up (Dryer Repair)
by mastaone 11/8/2009 12:44:09 PM(UTC)
Dryer will not heat up? (Dryer Repair)
by mel1293 10/3/2009 12:06:09 PM(UTC)
by clemmy 5/19/2009 7:19:42 AM(UTC)
Dryer Will Not Heat Up - Plug Changed recently from 4 to 3 prong (Dryer Repair)
by Seeking Help 1/11/2009 3:04:44 PM(UTC)
Maytag Gas Dryer will not heat up fully - princeton (Dryer Repair)
by brian.frasco@gmail.com 12/26/2008 1:28:44 PM(UTC)
Whirlpoool dryer will not heat up (Dryer Repair)
by ayellis 4/16/2008 6:47:04 AM(UTC)
