fusion1620
#1 Posted : Wednesday, July 8, 2009 10:17:50 PM(UTC)
fusion1620
Hi,
Top burners and broil work great.. Problem is the bake feature. Bottom burner lights up, but the flame is really low and it will not heat up to 400. It gets hot enough to cook a pizza, just takes twice as long. Any ideas?? Thanks...:confused:
Dan O.
#2 Posted : Thursday, July 9, 2009 11:50:20 AM(UTC)
Dan O.
Has it worked correctly in the past?
Does the broil burner work correctly?
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
fusion1620
#3 Posted : Thursday, July 9, 2009 5:47:31 PM(UTC)
fusion1620
Been working for 3 years so far. Broiler works fine...I'm replacing the bottom igniter. Hopefully that works....:cool:
Dan O.
#4 Posted : Friday, July 10, 2009 7:27:08 AM(UTC)
Dan O.
That should rule out an installation/setup problem.
It could be a possibility, yes... or the oven gas valve.
LINK > Hotpoint RGB790SEH3SA Oven Ignitor
LINK > RGB790SEH3SA Oven Gas Valve
Let us know how you make out.
Dan O.
=D~~~~~~
