gbove
#1 Posted : Wednesday, July 8, 2009 4:01:11 PM(UTC)
gbove
Hello, My sister is moving out of the state and has given me her brand new front load washer and dryer. During the move, the front door of the washer was cracked. :( There is a glass inner door that is fine and the door latch closes just fine. Is it ok to run the washer???? I don't think it will leak and I don't have the $155.00 for the part to fix the cracked door. Please let me know what you think and if you have any suggestions to fix this part for less $$$.
Thanks for your help.
Gina
sidfink43
#2 Posted : Thursday, July 9, 2009 4:18:36 PM(UTC)
sidfink43
Well, cannot say I have ever run one like that, but if the inner part is sealed I see no reason why you cannot operate the machine.
Good luck, and post back and let us know how it worked out.
Maytag Front Load Washer Model MHW8000AW0 (Washer Repair)
by Lery 4/8/2021 8:31:13 PM(UTC)
MHWE550WJ01 Maytag Front Load Washer No Water (Washer Repair)
by alligatorous 7/27/2020 11:07:06 PM(UTC)
Maytag Front Load Washer Leaking During Spin Cycle (Washer Repair)
by michelleyeo 12/11/2015 9:34:09 AM(UTC)
Maytag Front Load Washer (Washer Repair)
by dengchr 2/5/2014 7:24:25 AM(UTC)
Maytag Front Load Washer Thumping (Washer Repair)
by Papa_omero 9/25/2013 5:45:38 AM(UTC)
Maytag Front Load Washer Issue (Washer Repair)
by milli20 9/5/2013 1:42:47 PM(UTC)
Maytag Front Load Washer - on, but not working (no codes) (Washer Repair)
by Thuender 5/27/2013 3:25:47 PM(UTC)
Maytag front load washer will not spin (Washer Repair)
by tmichael 2/27/2012 1:23:16 PM(UTC)
maytag front load washer/holding water (Washer Repair)
by bmetsa 12/26/2011 1:56:06 PM(UTC)
Need bearing kit Maytag Front Load Washer (Washer Repair)
by lgmccoy1 12/11/2011 5:26:12 PM(UTC)
Maytag front load washer will not fill with cold water (Washer Repair)
by gclosius 11/27/2009 2:58:48 PM(UTC)
Maytag Front Load Washer Stops at 8 Minutes (Washer Repair)
by djack98157 11/17/2009 8:00:19 AM(UTC)
by dannyrwalls@yahoo.com 11/13/2009 10:56:38 AM(UTC)
Maytag front load washer squeaks (Washer Repair)
by thermalsol 12/10/2008 10:07:17 AM(UTC)
